Re: Thunder volt coil
Posted by glennster on March 18, 2011 at 09:32:51 from (75.57.126.3):
In Reply to: Thunder volt coil posted by redgems on March 17, 2011 at 21:04:20:
you will need to get the cylinder head fixed evenntually. you can put umbrella seals on the valves to stem some of the oil problem, and for now, go to napa and get some anti-fouling caps for the spark plugs. they screw on the end of the plug and pull it out of combustion chamber so they dont foul as quick. i havent heard any good reports on dennys, check on buyer seller feedback forum down below for more info on them. last resort on the coolant leak, if it is pulling water in the cylinder, you may try some stop leak in the radiator. be better to fix the head tho.
