Re: Farmall B cultivator
Posted by gene bender on March 19, 2011 at 08:26:45 from (67.55.227.7):
In Reply to: Re: Farmall B cultivator posted by corbincdc on March 19, 2011 at 04:44:31:
I dont see any reason mounting it back will stop the lift from working. Which lift levers did you get the two that raise each row or the one with a short lever and a long one that lifts both sides together. I hope you didnt get the levers for the Exhaust lift as they wont work for hand lift. They can be modified for hy lift. I have a set that was used for hy lift using a Char-Lynn Power Pac that runs off the pto. I have those systems also and they work well. I see what you are doing now and it should work if you can get the frame to clear the wide front. By moving it back should work just fine mite need to cut the outside tooling bars off a little to clear the tires. I do have cult parts if you need some.
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
