Re: Farmall B cultivator
Posted by Jim Becker on March 19, 2011 at 09:41:20 from (173.57.163.253):
In Reply to: Farmall B cultivator posted by S2710 on March 18, 2011 at 22:03:42:
Between moving the cultivator back and the larger rear tire diameter, it will probably get pretty tight. Interference with the tires is likely. If you keep the home-made rear wheel shields it will be even tighter. You can find longer spring trips if you need them to get the cultivator to reach the ground. You will be spending more than another $40 to get something that works.
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
