Re: H timing
Posted by glennster on March 19, 2011 at 12:26:58 from (99.90.9.153):
In Reply to: H timing posted by oldtanker on March 19, 2011 at 11:14:38:
you can time the engine with just a test lite. remove #1 spark plug, crank engine over to compression stroke. locate timing marks on crankshaft balancer. bring the first notch up to the pointer. you will now be at tdc. hook test lite to battery power and use wire from coil to distributor for ground. with points closed, lite will lite. rotate distributor slightly till lite goes out. tighten everything down. should be good to go. from there you can start engine and set timing by ear.
Today's Featured Article - The Great Escape - by Dave Hollrah. It all began Monday with a little baling of second crop on the lake shore field, and as I drove out past my sister and her hubby's place, this small calling sound could be heard from the general direction of their manure pile. Out of the yard, over the cows and bale piles, through the dozer piles, poplars, and brush, out onto the ditch grade road, past the noisy 6.2 diesel engine pulling my well traveled Suburban along. Well it sure didn't take me long to figure out what it was because I alrea ... [Read Article]
