Posted by glennster on March 19, 2011 at 16:37:40 from (99.90.9.153):
In Reply to: Re: H timing posted by teddy52food on March 19, 2011 at 15:38:37:
i just peeked in the owners manual for my h. it says crank engine over until the first notch on the drive pulley is in line with the pointer. this is with a magneto type ignition, but should be about the same for a distributor, you can get an initial timing point to get the tractor started. then fine tune by ear, or, if you have a timing light with an adjustable advance, and you know what advance weights are in the distributor, you can use the timing light to time accordingly. the notch to grease the pilot bearing is a ways around the pulley, look for a single notch by itself.
Today's Featured Article - The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
