Re: H Help Please!
Posted by Roy Prins on March 19, 2011 at 17:30:12 from (96.31.4.122):
In Reply to: H Help Please! posted by pete_5959 on March 18, 2011 at 18:33:35:
i would bet you sucked in a screw from the carb. and the throttle plate is misplaced -- first thing is to take off the carb. and look-if that is what happened --take out the spark plugs and look in the hole to see if you can get the screw out thru the hole or you will end up pulling the head-fix the carb as necessary -- did that and been there!
