Re: Case-IH 3220 starter or solenoid
Posted by Jimb2 on March 19, 2011 at 17:34:28 from (99.240.236.11):
In Reply to: Re: Case-IH 3220 starter or solenoid posted by Cathy on March 19, 2011 at 16:45:27:
Hi Cathy, be sure to remove ground cable from battery before working on the starter. Hope you don't have a front end loader on the 3220 as it makes it more difficult to access the starter.
If you have the tools maybe you can do a quick fix on the solenoid. I found the following on the web:
STARTER SOLENOID DEFECTIVE (DELCO-REMY ONLY)General Information:With uneven wear of the solenoid plunger shaft, a lip will form on one side of the shaft and the engine starter will not engage. Temporary repair can be made by removing solenoid and rotating solenoid plunger shaft 180 degrees.
http://www.delcoremy.com/Documents/Starter-Service-Manuals/29,-38,-39MT-SSL-SOLENOID-REPLACEMENT.aspx
Good luck
JimB
