Re: International 404 hydraulics
Posted by Handyman on March 19, 2011 at 23:38:51 from (216.201.66.234):
In Reply to: International 404 hydraulics posted by Byron F . Stone on March 19, 2011 at 19:30:29:
It is only supposed to have 7 gallons of oil in the trans. you probably need to prime the pump to get the oil flowing again, when I had one I needed to change the pump out and to get it primed I loosened the hose fitting on the output line and poured oil in through a port in the top of the filter housing and then kept starting it and letting it run a few seconds each time untill it finally took a prime, be ready to shut the tractor off quickly when it does start pumping because the oil comes fast when it starts. check to make sure your crankcase isnt filling with oil also.
