Re: H timing
Posted by riverbend on March 20, 2011 at 08:49:20 from (74.46.182.2):
In Reply to: H timing posted by oldtanker on March 19, 2011 at 11:14:38:
Set the points and timing marks as noted below. Loosen the distributor mounting bolts and turn the distributor body an inch or so clockwise (while looking at it from the cap side). Pull the coil wire out of the cap and hold it near a ground (the distributor body). Turn on the ignition. Rotate the distributor body back counterclockwise. When you get a spark it is in time. Tighten the distributor mounting bolts.
Greg
Today's Featured Article - Show Coverage: Fair Weather Tractor - by Dave M.. No, Fair Weather isn't some rare brand. It's the kind you can't leave out in the rain. Here's how it happened. I had been casually looking for a tractor for weeks. I saw a few 9N's, but they had even fewer amenities than the 8N my Grandpa bought new in '52 with a Dearborn loader. That was 10 years before I was born, so I grew up thinking that 8N was the world's best tractor. Grandpa had greenhouses, with over half an acre under glass, and that 8N did almost everything. It was the only ... [Read Article]
