Posted by Janicholson on March 20, 2011 at 11:29:47 from (64.61.211.243):
In Reply to: 350U hydraulic problem posted by tom dowling on March 20, 2011 at 09:06:05:
The control handles can fail. It will feel like a dead chicken leg if it is stripped at the control. If it feels Normal, does the engine bog a little when attempting to raise or lower, If so the safety valve in the cylinder might have gotten stuck. If it does not it is in the inside hydraulics. The pump drives the distributor, so the shaft is OK. The key on the shaft turning the gears in the pump could be sheared, (not high likelyhood). The suction screen could be blocked, or the tiny regulator valve and screen could be stuck. Keep us informed. Put blocking under the blade or take it off before relieving pressure! Jim
Today's Featured Article - What Oil Should I Use? - by Francis Robinson. I keep seein this question pop up over and over again in discussion groups all over the web. As with many things there are often several right answers and a few wrong ones. Some purist I'm sure will disagree to no end with what I will tell you but most of us out here in the real world don't really care do we ? Some of them only bring their noses down out of the air long enough to look down them anyway. If you are like me you are only doing this old tractor stuff because you enjoy it. You
... [Read Article]
Latest Ad:
[More Ads]
