Posted by Bob M on March 20, 2011 at 12:58:08 from (67.240.171.41):
In Reply to: C oil pressure posted by Denis in MI on March 20, 2011 at 12:29:43:
First thing I'd do is change the oil and filter. Could be the old oil is diluted with gas, etc. The oil may simply be too thin for the pump to hold pressure when it gets warmed up.
If no change swap the oil pressure gage for a known accurate gage and see what you get.
If pressure is still low then look at the oil pump. It could have a worn or warped bottom cover.
Beyond that you'll need to go deeper inside the engine for a fix.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
