Re: wiring diagram on H
Posted by Janicholson on March 20, 2011 at 13:22:21 from (67.72.98.45):
In Reply to: Re: wiring diagram on H posted by bmagee on March 20, 2011 at 12:54:04:
The L terminal on the VR is used by the system to supply load current to the tractor directly from the generator. The Bat terminal is used to charge the battery through the amp gauge. If you leave the lights hooked up to the amp gauge and ignore the L terminal, it will work fine. If you disconnect the lights and ignition switch supply wire from the amp gauge and hook it to the L terminal it will work fine. In all cases the grounded light switch terminals L and H positions. should not be attached to anything because the regulator is now in control of the gen. Jim
