Re: changing H engine from distillate to gas
Posted by Janicholson on March 20, 2011 at 13:30:58 from (64.61.211.243):
In Reply to: changing H engine from distillate to gas posted by amnion on March 20, 2011 at 13:13:18:
As Tyler indicates it is OK as is.
If you want it to be as efficient as possible (HP/Hrs/Gal. of fuel) swapping the head for a Gasoline head (H, SH, 300, 350,) and putting sh sized pistons/sleeves, and domed pistons in it will make a great tractor out of a very good one. A 350 cam and intake/carb would wake it up even more. Be careful to match the piston pin size with what you have so as to not be dramatically disappointed in a batch of parts. Jim
