Posted by Janicholson on March 20, 2011 at 13:44:05 from (64.61.211.243):
In Reply to: solenoid wiring posted by tonastoy on March 20, 2011 at 13:28:32:
There is a heavy (10ga) wire hooked to the battery cable stud on the Relay (that thing is a relay, not a solenoid, but is is often called the wrong thing by tradition, oh well) that wire goes only to the amp gauge. it should be the only thing on that side of the amp gauge. From the other side of the amp gauge a wire(12GA)(among many other) should go to the ignition Key. This supplies volts to the coil. Another from that gauge terminal goes to the starter button. From the starter button, a 12ga wire goes to the small terminal on the Relay in the picture (should have an S near it)closest to the battery connected stud. This energizes the relay causing the starter to spin. A 12 gauge wire from the farther terminal (next to the starter connected stud) Usually with an I label next to it, goes to the ignition coil. It connects to the coil on the coil terminal not connected to the distributor. This wire gives full starting voltage to the coil bypassing the ballast resistor. If the tractor is 6 volt, or has no dropping resistor, this wire and terminal can be ignored. I hope this helps. Jim
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
