Re: wiring diagram on H
Posted by Janicholson on March 20, 2011 at 14:08:18 from (64.61.211.243):
In Reply to: Re: wiring diagram on H posted by bmagee on March 20, 2011 at 13:31:35:
No wire is attached to the light switch grounding terminal. This is the terminal that has a resistor attached, that is not a part of the lights.
When the switch is in the L position Full ccw the field of the gen was originally grounded through the resistor to the body of the light switch. when the Switch is in the H position, or D position, or B position the same terminal id directly grounded.
This terminal needs to be disconnected, it is not used. The light switch is used and gets its power from the fuse. There is a front light terminal that attaches to the front lights, and a rear light terminal that attaches to the rear light. The front light terminal is connected through a resistor (different one than used for the field circuit) when the Sw is on D, and through no resistor when the Sw is on B.
The rear light is on full power in both D and B positions. Use an Ohm meter to assure these connections. there should be no sparks when connecting the cable unless it is wired wrong, or the light switch is on! Jim
