Re: wiring diagram on H
Posted by Janicholson on March 20, 2011 at 14:32:05 from (67.72.98.45):
In Reply to: Re: wiring diagram on H posted by bmagee on March 20, 2011 at 14:17:33:
Yes. The voltage regulator completely eliminates the use of the light switch in the charging system. remove the wire from the switch, and the VR. There is only one wire from the Field terminal on the gen. It goes to the F terminal on the VR, no other wires.
I do not think, however, that the discharge is caused by that wire. it would just override the voltage regulator and make it charge. There should be no spark when connecting the battery with every thing turned off (light switch Full CCW) Jim
