Posted by Janicholson on March 20, 2011 at 14:46:38 from (67.72.98.45):
In Reply to: H Argh! posted by pete_5959 on March 20, 2011 at 14:34:40:
Pulling the oil pan will tell you the story. If a rod broke and destroyed internal surfaces, oil pump and or the block itself, it will require substantial effort to make it right. The most common problems that make internal noise are broken rods, spun bearings and broken crankshafts. All are visible with the pan off. If the block and cam are OK, and the crank was untouched, A engine Kit will be all that is needed. If there is damage to the journals and block it might just be best to get a different engine and rebuild that. Super H or 300-350 would be nice! If the crank is measured and found to be good, and the block is OK it might be an in frame proposition. Otherwise the engine will need to be removed. Jim
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
