Posted by El Toro on March 20, 2011 at 17:17:49 from (108.3.200.96):
In Reply to: Farmall H seized posted by Dan Handy on March 20, 2011 at 15:34:23:
Do what HickDale suggested, but make sure you're away from any building and remove anything flammable. I would only heat one at a time and have the rod cap off the piston you're heating. Take a piece of 2 X 2 oak and a big hammer and tap on the oak with the hammer and see if the piston will move. You can use a puller on the sleeves once you have the pistons out. Always take pictures, make notes and a few sketches. Use a memory card too. Hal
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
