Re: Farmall H seized
Posted by gene bender on March 20, 2011 at 17:50:46 from (67.55.227.7):
In Reply to: Farmall H seized posted by Dan Handy on March 20, 2011 at 15:34:23:
I would look in the sparkplug holes and you can see how bad the walls look. If they are covered with rust dont wast any time pull the head and pan as the engine is probably junk. I just tore an engine down after looking at the walls when the plugs were removed. I could have soaked forever and that engine would not have freed up.
