Posted by Dean Olson on March 20, 2011 at 19:39:32 from (76.31.42.124):
In Reply to: C oil pressure posted by Denis in MI on March 20, 2011 at 12:29:43:
Also check the bolt that holds the oil filter in place. It has a very small hole in the side that can plug.
I just bought a 200 that would only run about 20 psi and fade down to 10. I dropped the pan, cleaned everything up. I swapped the oil pump for a known good one, replaced the filter and cleaned the hole in the side. I had to use a drill bit to clear the filter bolt hole because it was so solid. Added some fresh oil, fired it up and now oil pressure runs 50-60 psi. I checked the old pump later and sure enough the bottom cover was warped and the gasket was blown.
I got a heck of a deal on a Farmall 200 with fasthitch because the previous owner didn't want to "rebuild the motor!"
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
