Re: Farmall 450 Gas Ball Bearing??
Posted by randy hall on March 20, 2011 at 19:54:21 from (209.143.0.64):
In Reply to: Farmall 450 Gas Ball Bearing?? posted by Tony_Idaho on March 20, 2011 at 19:05:06:
the most common bearing failure is the bull pinion. you can take the brakes off and the plate behind the brakes and pull the pinions out and inspect them.
