Re: wiring diagram on H
Posted by bmagee on March 21, 2011 at 02:44:47 from (99.162.59.220):
In Reply to: wiring diagram on H posted by bmagee on March 20, 2011 at 11:27:52:
Jim,
Down to the lights now. I have the ignition switch discharging as it should when I pull it out. The lights however still do not work. the amp gauge does not discharge either.
I have re-checked my light wires, made sure the coiled resistor is not touching anything that it shouldn't but still nothing.
sometimes, not all the time, when I attempt to put the + cable on the bat. it sparks. I have noticed a trend that if the light switch is in the ON position it does not.
do teh swicthes go bad. all worked well, before I started my re-wire :?
