Re: Farmall 450 Gas Ball Bearing??
Posted by RPM1941 on March 21, 2011 at 05:57:22 from (173.25.71.175):
In Reply to: Farmall 450 Gas Ball Bearing?? posted by Tony_Idaho on March 20, 2011 at 19:05:06:
I think you should check the axles inner & outer brngs, if it hasnt already been done that you know of, next thing that will happen is another ball will ride around the bull gear and bust the bottom of the rear frame main housing. At least drain the lube oil and refill with new.
