Posted by Jimb2 on March 21, 2011 at 09:21:54 from (99.240.236.11):
In Reply to: 424 lift problems posted by Travis Atkinson on March 20, 2011 at 17:53:41:
Hi Travis, make sure the draft control lever is all the way forward. Check the slop in assembly that the top link connects to on the hydraulic housing. If there is to much slop the top link assembly will activate the draft control which is the shiny shaft sticking out of the hydraulic housing. The slop can be adjusted by a screw driver thru the hole in the top of hydraulic housing and loosening the jamb nut on top of square block.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
