Re: Farmall 450 Gas Ball Bearing??
Posted by pete 23 on March 21, 2011 at 10:26:15 from (173.87.146.142):
In Reply to: Farmall 450 Gas Ball Bearing?? posted by Tony_Idaho on March 20, 2011 at 19:05:06:
You need to pull the pto so you can take a look and clean it out. Count the balls. Want to get them all. Ya, it could be from a previous failure but you won't know if you don't look. Most likely inside axle ball bearings. They were the bad ones along with bull pinion. Make nice grooves in housing also when they fail. If it is an an axle bearing I much prefer to pull axle housing although you can push axle out with out doing that. Harder to clean it up though.
