Re: Correct Overhaul Kit for New Block?
Posted by El Toro on March 21, 2011 at 17:21:50 from (108.3.200.96):
In Reply to: Re: Correct Overhaul Kit for New Block? posted by AFaist on March 21, 2011 at 14:37:51:
The diameters are 3-5/16" and 3-7/16". You should be able to use the 3-1/4" sleeve kit without any machining to your block. Be sure to buy your insert bearings from the shop that's doing your crankshaft. Your sleeves should measure 7-1/16" in length. Hal
