Re: Farmall M Axle Housing Question...
Posted by Stemmy on March 21, 2011 at 17:44:49 from (206.49.63.193):
In Reply to: Farmall M Axle Housing Question... posted by Rick(MN) on March 21, 2011 at 17:27:42:
Rick(MN) said: (quoted from post at 17:27:42 03/21/11) Before you go digging too deep on it, make sure it is actually the gasket and not the bull pinion seal. 90% of the time you will find its not the gasket. I made that very mistake many years ago in tech school. Wasnt the first person to ever make it and wont be the last.
the gasket is ripped (somehow) and sticking out a pretty good bit in one spot and you can see the oil line from where its leaking, So im assuming its just the gasket. But im sure with my luck the seal is bad too.
This post was edited by Stemmy at 17:45:50 03/21/11.
Today's Featured Article - What Oil Should I Use? - by Francis Robinson. I keep seein this question pop up over and over again in discussion groups all over the web. As with many things there are often several right answers and a few wrong ones. Some purist I'm sure will disagree to no end with what I will tell you but most of us out here in the real world don't really care do we ? Some of them only bring their noses down out of the air long enough to look down them anyway. If you are like me you are only doing this old tractor stuff because you enjoy it. You ... [Read Article]
