Don't bother with the gasket. Get a couple of bolts that are a couple inches longer that the original. Support the center of the tractor. Install the longer bolts, one in the front and one in the rear of the housing. slide the axle housing out as far as the bull gear will allow. Clean off both surfaces where the gasket is. Put a continuous bead of RTV where the gasket was, encircling the bolt holes. Bolt the housing back on the rear frame.
If you have a way to lift the weight off the tire it is a little easier but you can also get by using a board and smearing a little grease on it where the tire can slide. The hardest part is probably cleaning the gasket surface. It must be clean and oil free for the RTV to seal properly.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
