I think what you have apart is the pressure regulator valve in the MCV. Without it there will be no pressure to operate the brakes. The steering has a priority oil flow with it's own pressure regulator. The 3pt has a separate pump and hydraulic system.
There should be two springs, one inside the other. If the inner spring is still in the MCV assembly it may be keeping you from installing the larger spring all the way into the port.
