If you are going to go through this trouble at least make sure the inner axle bearings are good. They are the ones that go kaput and then the bull gear eats its way through the rearend housing. For what has been suggested it is almost easier to just remove the tires, pull the PTO, unbolt the bull gear and gently slide it off axle and then pull the whole housing. Sounds like a lot of work but you are sure to get everything clean and inspected rather than fiddle around squirting RTV in the gap and hoping it seals. Sometimes it works, sometimes not. Depends on just how clean and dry you can get it obviously.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
