Re: Correct Overhaul Kit for New Block?
Posted by gene bender on March 21, 2011 at 19:38:17 from (67.55.227.7):
In Reply to: Re: Correct Overhaul Kit for New Block? posted by AFaist on March 21, 2011 at 15:58:32:
If thats what it measures you can go with the 3 1/4 bore hi-dome giving you 135 cu in and 26 or so HP. I was quoted 52.00 per hole.
