Re: Re: Re: Front-loader hydraulic problem - AIR
Posted by big fred - nope on July 21, 2000 at 13:59:30 from (12.13.226.16):
In Reply to: Re: Re: Front-loader hydraulic problem - AIR posted by Gary Fry on July 20, 2000 at 16:45:05:
You won't have a hollow ram with a double acting, so everything I wrote above will be pretty useless, I'm afraid. Seems kind of strange they wouldn't bleed, though, perhaps you have a bad piston seal and what you are experiencing is just leakage past the seal. Either way, you really need to get the air out. When you compress oil, nothing much happens since it is incompressible, but when you compress air or any gas, it heats up, and at hydraulic system pressures, it can get REALLY hot, possibly damaging seals.
Post A Followup
: Re: Re: Re: Re: Front-loader hydraulic problem - AIR
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
