Re: Farmall H Bolster Thrust Bearing Source
Posted by sflem849 on March 22, 2011 at 07:56:39 from (69.197.84.192):
In Reply to: Farmall H Bolster Thrust Bearing Source posted by neblinc on March 21, 2011 at 13:22:36:
Isn't this the one that you can get a regular duty bearing for 10% of the cost of the bearing it calls for? IIRC it calls for some magic side thrust tolerant wonder bearing, but a regular bearing will work fine for most uses.
