Re: Super A sticking starter
Posted by Bob M on March 22, 2011 at 08:36:40 from (67.240.171.41):
In Reply to: Super A sticking starter posted by Bill byford on March 21, 2011 at 20:37:25:
Pretty common problem. Cause is worn starter drive (pinion) and flywheel ring gears.
Sometimes replacing the starter drive solves the problem. However sometimes new drive will actually make the problem WORSE.
Only solution then is to replace the flywheel ring gear. Unfortunately the tractor must be split to replace the ring gear. The good news is a new gear is relatively cheap ($35 or so). And once the tractor has been split R and R'ing the ring gear is straightforward.
