Re: Paint quality concern
Posted by loren in wi on March 22, 2011 at 13:10:43 from (69.179.16.37):
In Reply to: Paint quality concern posted by Goodman on March 22, 2011 at 05:56:10:
Self etch primer is only to be used on clean bare metal, that is going to have eighter epoxy or sandable primer applied over it. Applying too much primer will result in adhesion issues. I would recommend sand blasting the tractor, then applying 2 shots of epoxy primer, then applying your color in a wet on wet fashion. I use PPG epoxy and concept color on all my tractors. This will give you a paint job that WILL NEVER FADE or peel if done corectly. I have been painting for 25 years now, not saying there isnt a better way but this way works. It is not cheap by any means but it lasts. I am a certified PPG refinisher and have been for 15 years now.
