Re: Can you clean the injector holes in the head on an MD?
Posted by rustred on March 22, 2011 at 13:14:12 from (72.172.100.113):
In Reply to: Can you clean the injector holes in the head on an MD? posted by sflem849 on March 22, 2011 at 12:04:03:
most important to have new gskets and the dust seal o ring at top .as owen says the used ones cause exhaust to leak past and carbon up. hard to get used ones to seal. once tractor is running can check for leaks with some soap and water in a spray bottle. i use some emery cloth and air to clean them up.even when you remove the gskts can see if the were sealing. dont double them up either.should not need antiseize in the bore as thats the o rings job. good idea to use it on the bolt threads though.
