Re: H will not start
Posted by pintobill on March 22, 2011 at 13:49:31 from (72.51.225.33):
In Reply to: Re: H will not start posted by rustyfarmall on March 22, 2011 at 06:58:28:
I reinstalled the old governor
I checked the compression
Plug wires are on right
With #1 cylinder TDC on compression roter is to #1 plug wire on the cap
I put a carb off of another running tractor on it
It is firing
It is getting gas to the plugs
I checked the valve train and push rods
When I try to start it the engine turns over good when I try to choke it or spray starting fluid in it the engine still acts like it is wanting to vapor lock, its like it just siezes up. I can let it set for just a bit and it will whirl over fine again. Every once in a while it will hit like it wants to start but thats it. To me it acts like it is flooded, I let it set over night with the plugs out, put new ones in and got the same thing. I am out of ideas on what to do.
