Re: Do I need a ballast resistor??
Posted by twopop on July 21, 2000 at 15:47:46 from (208.209.103.51):
In Reply to: Do I need a ballast resistor?? posted by Brian Schoenberg on July 21, 2000 at 14:11:46:
if the resistor is built in you do not need another one.if you put one in you will not have enough voltage to operate the coil,you would probably get spark but it will be weak.check the # of the coil with your local parts house,they should be able to tell you if it has a builtin resistor
Post A Followup
: Re: Re: Do I need a ballast resistor??
