Re: ignition switch
Posted by Bob M on March 22, 2011 at 14:14:28 from (67.240.171.41):
In Reply to: ignition switch posted by robert e ratajczyk on March 22, 2011 at 14:00:38:
Unscrew the switch button from the rod. The switch assembly is then easily removed.
The button threads may be stuck pretty tight - warming it GENTLY may help it break loose.
