Re: Farmall B450 diesel value
Posted by Harold H on March 22, 2011 at 18:01:03 from (68.59.252.155):
In Reply to: Farmall B450 diesel value posted by Dean Olson on March 20, 2011 at 19:52:53:
Dean,
If you really wanted a one of a kind show tractor, you could buy the B450 and turn it into a cotton picker tractor. The flange type rear axle housings and axles from a M thru 560 will fit the B450 as will the bullgears and single front wheel and fork. The underside of the transmission top would have to be machined and drilled for the reverse forks. Flip the differential and you would then have a B450 cotton picker tractor. I have only known of one Farmall B450 being set up as a cotton picker tractor for use as a spray tractor many years ago.
Harold H
