Re: H still wont start
Posted by Janicholson on March 22, 2011 at 19:55:55 from (67.72.98.45):
In Reply to: H still wont start posted by pintobill on March 22, 2011 at 17:02:50:
The timing or plug wire order in the cap is not correct. There are many posts describing the process of finding #1 and setting TDC. then putting the wires in correctly. If it has had trauma to the cam drive gears in the front it could be that there is further issues driving the failure to start. Internally jumped timing is very possible. If when put in time at the distributor, it changes, suspect that. Jim
