f-12 clutch pedal
Posted by Carl Holloway on July 21, 2000 at 21:57:44 from (207.114.193.144):
The clutch pedal on my f-12 is loose. The bolt is loose that holds the linkage and the spring all together. My question is, does the bolt screw into the side of the trans housing or does it have a nut on the iside of the case. I would think that it screws onto the housing, if it does then i'll problbly have to try to tap in a larger diameter bolt. Any ideas out there. Thanks Carl
Post A Followup
: Re: f-12 clutch pedal
