Re: IH300U heated seat
Posted by Janicholson on March 23, 2011 at 13:17:55 from (199.17.6.194):
In Reply to: IH300U heated seat posted by Chas Weller on March 23, 2011 at 12:54:44:
The pressure control orifice and tiny screen in the valving is probably plugged and calling for pressure against a dead end passage. The pump is getting hotter, so do not delay fixing it.
Assure that all the Single or double acting switches on the control valves are turned fully, to one end of the sheet metal clip, or the other, and that the valves are centered and not partially applied. If these are good, I would suspect the orifice. Jim
