bn final drive
Posted by Bob Brothen on March 23, 2011 at 14:18:47 from (71.193.91.218):
I am trying to replace the axel seals on the final drive assy on my Farmall bn and have removed the seal retainer bolts behind the hub, axel retainer bolt, spacer and washer but am unable to tap the axel shaft out of the assembly.Can anyone give me some tips for removing the shaft? It seems to be a very tight fit in the bearing. The bearing will move within the casting but the shaft will not move out of the bearing.
