Re: 560 diesel oil cooler
Posted by Owen Aaland on March 23, 2011 at 19:46:39 from (65.174.247.90):
In Reply to: 560 diesel oil cooler posted by scotty-mn on March 23, 2011 at 09:11:39:
Early tractors user steel pipe with a short hose to connect to the oil cooler. Later tractors ran hoses instead of the steel lines.
The lower hose hose starts at the back of the cast elbow on the lower radiator hose. There is a 90° elbow and then either pipe or hose down the oil cooler.
The upper hose goes from the oil cooler up between the generator and block to connect to a horizontal port in the water pump near the cylinder head.
