Re: FARMALL M FRONT BOLSTER REPAIR(BEARINGS AND SEALS) GE...
Posted by glennster on March 24, 2011 at 04:49:33 from (99.90.9.153):
In Reply to: FARMALL M FRONT BOLSTER REPAIR(BEARINGS AND SEALS) GEAR O... posted by Mike1972chev on March 23, 2011 at 17:21:54:
there is a press in bushing on the top steering input shaft. also check the steering shaft for a groove worn in it. for a rebuild, carter and gruenenwald cgn.com sells a kit, has all the bearings, bushings and seals for a front end overhaul, about 160 dollars. like cnks said, you can use corn head grease in them too. your local john deere dealer sells it.
