Re: super c running rough
Posted by Bill in NJ on March 24, 2011 at 05:08:55 from (4.248.90.132):
In Reply to: super c running rough posted by brian1855 on March 23, 2011 at 21:09:01:
Are you sure it's hitting on all four cylinders and in the correct order. Mischief makers have been known to change plug wires. If the order is correct I would suggest pulling a plug wire and listening to the engine. If it changes there is something wrong with that cylinder. If it does not change put the wire back on and pull the next one. And so on down the line. If you locate a cylinder that changes it is either not firing or it could have a valve hung up. If no change is seen with the wiring, check the carburetor float. It could be hung up.
