Posted by Janicholson on March 24, 2011 at 05:27:45 from (199.17.6.213):
In Reply to: Slow Runner posted by John E/Pa on March 24, 2011 at 05:16:43:
There are a few possible issues. First is to determine what fast is. A strobe tach, or a shaft tach can help determine when it is running at fast idle. PTO at about 600, engine at the number stamped on the ID plate, or a little above. The linkage to the governor must move the governor all the way to the limit of the lever. If it does not change the length of the rod system to make it so. The governor rod to the carb could be out of spec too short, not letting the carb open (less likely, but shoululd be full open when the governor arm is pushing the throttle open. (can be shut off to check) The governor could have worn primary bearings, spring/s, and weights. Jim
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
