Re: Touch Control
Posted by CNKS on March 24, 2011 at 18:10:49 from (216.144.104.128):
In Reply to: Touch Control posted by Allen Goodman on March 24, 2011 at 12:19:10:
It may or may not be stuck enough to require disassembly. If the unit had good oil in it when you took it off it should not be frozen by rust. Water in oil is a different matter. The pistons create a lot of suction and are hard to move even when just installed. If you can get a long rod or screwdriver in the hole in the end, try prying with the rod against the edge of the reservoir, or put loop of thin chain thru the hole and pry on that.
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
