Posted by Nebraska Cowman on March 25, 2011 at 06:52:26 from (66.252.115.12):
In Reply to: IH sycle mower help posted by achodges1 on March 25, 2011 at 05:47:42:
All that stuff has to be "right" if you want it to cut hay. The bar has to be kept in "register" which means the sections must center in the guards at BOTH ends of the stroke. Those are all wear parts as to the ball and socket. Lost motion is a big no no. Also all the sections must be sharp and fit closely with sharp guard plates giving a scissor action when cutting. Rust, and dull, broken, and miss-fitting parts won't cut it. {pun intended}
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
